Brief Description: Right wing - tank attach brakets
Match drilled tank attach brackets to spar Fastened nut plats to tank attach brackets Bolted tank attach brackets to spar Back inner most bracket to spar Fastened nut plats to spar Bolted inner tank attach bracket to spar Clecoed tank baffle to tank attach plats Checked Baffle/Spar alignment - OK Match drilled baffle to tank attach brackets
