TOM'S WEB SITE
Date:  6-26-2005
Manual Reference:  7-9
Brief Description:  Left Tank - Tank Leak repear
Pressed up the fuel tank Immersed in the swiiming pool Located small leak around drain fitting Located larger leak on outside rib between baffle and rib Cleaned out the sealant, located a rivet that had squeezed the joint open Removed Rivet Resealed joint Replaced Rivet
