Clecoed Skin to Baffle to Spar Match drilled tank attach brackets to baffle Removed skin and match drilled remaining holes Assembled tank & baffle, clecoed to spar Match drilled tank joint plate to tank Countersunk baffle attach rivets Shaped and drilled tank mount bracket and stiffeners Marked and drilled the leading edge hole for the "flop tube"
