Deburred and primed top skins Deburred bottom wing skins Refitted top skins Fitted bottom outboard skin and marked the references for the tie down hole Removed pull rivet from the main spar / rib repair Drilled ot hole to #19 Fitted an AN3 nut, washer and bolt
