Brief Description: Right Wing - Control Surface Hardware
Fitted and match drilled the aileron and flap braces Assembled, fitted and match drilled the ailerone brackets. Deburred and dimpled airleron brace and skin Clean and prepared braces and brackets Primed braces and brackets Clean and prepared trailing edge exposed skin Primed trailing edge of the exposed skin
