After a break of almost a month, it was possible to get back into the garage. Final assembly of the tank plate, sender and pickup tube Fastened components, torqued and seald bolts. Attached and sealed cover to tank rib. DECISION: Should I ever need to service this component, it will be easier to replace the entire sub assembly. Located and drilled the vent fitting hole on the inboard rib Cut and flared tube Installed bushings fed tube and mounted fitting with sealant. Bent far end of tube to touch highest point in the tank [tail down position]
