Brief Description: Right tank - final assemble prep
Deburred and dimpled tank skin Dimpled tank ribs Dimpled stiffeners Cleaned and prepped tank interior surface Prepared 'ProSeal' Back rivetted tank stiffeners to tank skin. Working with the ProSeal isn't nearly as bad as I had thought it was going to be. Only point of note is that the process is very time-consuming, the ten stiffeners took around an hour to complete. I think that going forward, I shall mix very limited amounts of pro-seal as I work with each part to be rivetted, Further the mixing process needs to be more accurate. Mixing by eye seems to work, its just that the batches may well differ beyond a standard deviation. Cleaned tools / Skin
