Brief Description: Right wing leading edge assembly
Clecloed leading edge ribs into skin Removed bottom skins from right iwing Positioned leading edge Marked and positioned tank joint plate Clecoed leading edge ribs to spar Clecoed leading edge skin to spar Checked tank joint plate alignment Drilled tank joint plate
