Finish bucked the main spar/rib rivetts Cut and match drilled the wing walk doubler plate Clecoed on the wing skins 702/703/704/705 Checked skeletong for true and plumb Noted 1/64" difference from plumb over the entire structure in the wing stand Match drilled skins to skeleton
