Prepare trim tab skin and spar Deburred and Dimpled skin and spar Fitted and drilled trim hinge Primed skin and spar Fastened skin to spar Blind fastened trim trim ends Matched hinge to elevator Fastened hinge to elevator Fistened remaining elevator skin Adjusted trim hinge skin to clear elevator skin in down transition Ground down nut plates to clear trim servo
