Fastened stiffeners to skins Fastened trim double plate to port skin Fastened nutplates to doubler plate Bent skins to final shape Assembled Counter balance ribs Attached counter balance skin and counter weight Drilled Weight to #12 Repeated or left side Attached counter balance skins to spar Attached inboard rib to spar Match drilled spar Clecoed skin to stbd elevator skeleton
