Remove clecos and angle from trailing edge Cleaned trailing edge Partially squeezed trailing edge rivets Full set trailing edge rivets with a ground set Trailing edge is good and straight Roll / Bent leading edge on port and stbd skin Clecoed halves together Drill to #30 Set to Blind rivets Measured edge. Lower curve is 1.75 " Upper curve is 1 5/8" as per plan. RUDDER COMPLETE.
