Brief Description: HS Forward Spar, Ribs and Port Skin
Finished the forwardspar stiffeners Bent the stiffeners Trimed P / S HS 702 web and flange Prepared HS ribs Fluted rubs Assembled P skeleton Fitted P skin Fitted / drilled HS 404 / HS 405 Fitted / Match drilled stiffeners Match drilled front spar
