Brief Description: Flaperon installation on RH wing
Same procedure as for the LH wing: reamed the flaperon hinges and installed the brackets on the #1 and #5 hinge. Then using saw horses as a support I positioned the flaperon hinges in place. Checked the position and drilled/clecoed them into the ribs and reinforcement plates. After confirming there was no binding and position was still correct, I drilled/clecoed the remaining hinges onto their ribs.
