Brief Description: LH wing trailing edge reinforcements and wingtip
Installed the trailing edge reinforcements onto the left wing. Started by pilot drilling the left halves and then installed and counterdrilled the right ones. Slight trimming was needed for the outboard and inboard ones so they would fit flush with the ribcab. In the afternoon I started on the wingtip mounting plate, layed out a rivet pattern and clamped/drilled and clecoed the strips in place. The trailing edge reinforcements still have to be alodined.
