Deburred and bond prepped the mass balance weights and then hysoled and rivetted them in place. Also covered the remaining flaperon balsa tip in hysol and the back of the rivets on the flaperon trailing edge. As I broke a false rib a while ago on the left wing I also hysoled a new false rib in place, to be varnished later together with the pitot mounting plate.
