Brief Description: Installed N1 ribs and jury struts
Started early in the morning putting the fuselage out with the wings on, so the #1 ribs could be installed accurately. Both sides bond prepped and hysoled in place. In the afternoon I continued by installing the jury struts. Quite difficult as it had to be perpendicular to the horizontal bottom of the plane (not the wings) and pointing straight forward.The jury brackets temporarely held in place by zip ties. Then I confirmed that the wing lift struts were not pushed/pulled by the jury struts. After everything was double checked I drilled and clecoed the jury strut brackets onto the wing spar.
