Brief Description: Brake lines and rudder cable swaging
Cut and installed the Nylaflow brake tubing around the rudder pedals. Added heat schrink to avoid chafing. Tubing onwards from parking brake valve and towards brake fluid reservoir to be completed. Then I made sure the rudder pedals were correctly aligned, and swaged the pilot and passenger side rudder cables together. Rudder pedals and brakes now completed. Finished the day by trimming, and installing the centre console side panels.
