Brief Description: Firewall and boot cowl installation
Started on fitting the firewall. Installed the side plates of the firewall at the foot wells. Side panels rivetted with high temp sealant. Took quite a while to fit the firewall to sit neatly, the holes for the engine mount bolts had to be slightly enlarged. Fuselage mounts for the engine mounting reamed to size, bottom bolt hole drilled. Started on fitting the boot cowl.
