Assembled and the mixer assembly. Reamed the weldments and installed the bearings in the fuselage. Installed the mixer assembly in the aircraft, Bolts torqued to correct value. Installed connecting tubes up until mid fuselage bell cranks as I’m missing the correct bolts, not torqued yet as adjustments need to be made.
