TOM'S WEB SITE
Date:  4-5-2020
Number of Hours:  4.00
Brief Description:  Continued on spar reinforcement fittings and wing
Finished deburring and prepping the spar reinforcement fittings. I coated the inside ones as the outside ones will be coated once the N1 rib will be installed. As the factory predrilled the 4 corner holes in the wing strut brackets, I had to just reconfirm the position and start drilling throught the pilot holes into the spar and spar insert.
