Brief Description: Finished installing control column and flap/rudder
Sanded the nylon control column bearing down and torqued to specified value. Attached the control column to the rest of the flight control rods. All rod ends which still need to be adjusted were not torqued yet. Continued by assembling the flap and rudder handle brackets. I needed to swap out the bolts for the flap bracket with longer ones due to the thickness of the self fabricated aluminium part. Brackets testfitted in to centre console and pilot drilled and clecoed in place.
