Rough Trimmed the seat pan to fit Floorboards final fitted and sanded. Tried a test stain. Think I'll go with the cherry. FINALLY got the right column bearing to be bind-free. Installed and torqued bolts. LH bearing still has slop w/ column at the aft stop, and binds toward the forward stop. The column is out-of-round, so I'll need to think about how to get a smooth but tight fit here. In addition, torquing the bolts distorts the bearing and has made fitting difficult.
