Brief Description: Rudder - Improved top gusset fitment
Also improved gusset attachment on RH top rudder gusset. Small, 2" section where pressure was too low. Used 80 grit sand paper in section to eliminate dried epoxy. Spread into joint with razor blade and hard bristle brush and improved pressure on joint adequately.
