Rudder horn slot cut from lower L hand rudder gusset. Fitment and gluing of 3 left side gussets, including lower rudder gusset. Final rudder rib fitment and remaining gussets are remaining.
Getting a little better with T88 mixing and application. This set of gussets had just the right amount of squeeze when stapled and the gussets were much cleaner.
Rudder horn not part of this part of the kit so I'm curious how it will be attached as the space to reach the bolt holes in the lower rudder spar is snug.
