TMN's Mini Max Build Log
1650R Eros
Rudder - trailing edge glueing
Glued trailing edge to top and second to top rudder rib. Some cleanup will be needed as top rudder rib was 2mm wider than trailing edge. Will clean up this mis-fit prior to gusset attachment
1650R Eros Home
49
