This evening, I took the plywood inserts that I made to reinforce the fiberglass tips and epoxied them into place after checking the tip fit with the new attaachment strips added to horizontal stabilzer. After the Epoxy set, I marked and cutout the foam backing material I will use as the fondation for the fiberglass cloth that I am going to use to finish aft exposed portion of the fiberglass stab tips. I still have to buy the fiberglass fabric and resins. This will be a new experience for me (fiberglassing NOT buying!).
