Brief Description: Set Bellcrank Angle/Ran Pitot Tubing/Squared Wing.
Set RH wing bellcrank angle to rib centerline at 25 degrees with aileron in neutral position while other end of aileron push rod is lined up at station 0 of main spar. Ran pitot tubing through root rib and ribs #1 through #4. Squared RH wing and prepared for final attachment of wing skins.
