Brief Description: Positioning & Drilling Flap & Aileron Hinge Halfs
Positioned RH wing half hinges for the flap & aileron and pilot/updrilled holes. Attached flap & aileron to RH wing to do a preliminary check for preload and binding---no preload or binding. Also checked gap between flap and aileron---plans call for a minimum gap of 3/16 of an inch. I am good with a gap of 1/4 of an inch.
Positioned Flap & Aileron Hinge Half on RH Wing.
Pilot Drilled RH Wing Hinge Half for Flap.
RH Wing Hinge Halfs Updrilled with Flap & Aileron Attached.
