Brief Description: Aileron Bellcrank Installation/Aft Wing Rib #9 Ass
Made the Aileron Bellcrank Assemblies for both the right & left wing halfs. Worked carefully with fine emery cloth wrapped tightly around the appropriate sized drill bit so that I could achieve a press fit of the Bronze Pivot Bushings in the Angles & the Steel Bushings that are attached to the Aileron Bellcrank Plate.
