Brief Description: Attaching Vertical Tail Surface Tip to the Vertica
Measured and drew cut lines on vertical tail tip. Cut along cut lines with a Dremel tool, and sanded to final shape. Fitted tail tip to vertical stab and matched drilled pilot holes.
Measured out the cut lines for vertical tail tip.
Made cut along cut lines using Dremel tool.
Tail tip fitted to vertical stab, and pilot holes drilled.
