TIMOTHY'S WEB SITE
Sonex
SNX-W07-01
Fitting Wing Tip Rib
Using work instruction No. SNX-W07-01 I Fitted & Pilot/Updrilled RH fiberglass wing tip rib to RH wing skins.
Shaped Fiberglass Wing Tip Flanges to Fit with Skins & Pilot Drilled.
Usded Drop Light to Assist in Locating Holes on Tip Attach Angle Before Pilot Drilling.
Finished Updrilling All Holes For Wing Tip Rib to Skins.
Sonex Home
393
Aft Fuselage
Ailerons
Elevator & Horizonta
Flaps
kit Delivery & Inven
Rudder & Vertical St
