Cowboy's RV-10
Date:  2-8-2010
Number of Hours:  2.50
Manual Reference:  11-5
Brief Description:  Drill Hz Stab Fwd Spar and Spacers to Tailcone
Step 1: Cut wood block as spacer to hold Hz Stab in position when measuring and drilling.
Step 2: Square Hz Stab with tailcone using long seamstress tape. Alignment took a slight clockwise twist (2.5 mm our of alignment measured at aft spanwise position).
Step 3: Final-Drilled with #12 bit (12 in long). Plans called for Match-Drilling with 3/16 in bit but all I had was short bit. I had great results with the long #12 when I built a temp drilling jig with taylor built wood blocks. This worked well too. Holes nice and straight and bolts fit snug.
Some normal scarring on hand
Jig and Alignment Marks
Deburred and Bolts back in
