Brief Description: Rivet Middle Inspar Rib and upper front spar
- The Middle Inspar was easily reachable with the Bottom Inspar Rib removed. - Access to the upper spar required removing some of the clecos along the top rib and rear spar. It was a little tight fit for my arm getting at some of the distant rivets but once in it work out ok. By this time I'm getting more used to operating gun and bar together so shop heads are beginning to improve even in cramped areas.
