Pete's Bearhawk Web Site
Date:  11-3-2009
Number of Hours:  1.00
Brief Description:  Final leading edge formed.
Well, I had finally saved up enough to order the replacement aluminum for the final top and bottom skins for the right wing which I had previously screwed up (actually I had screwed up two top skins and used the bottom right skin to form a top skin from a previous screw up blah blah blah). ANYWAY, I got the aluminum in and trimmed the final top right skin to size. I then clamped the "short"-already-drilled skin to the new skin and match-drilled the holes where the nose ribs were already drilled. I then formed the leading edge on the new skin making tripple sure that the center of the leading edge was exactly on 17" (the same as all the others).
