Pete's Bearhawk Web Site
Date:  1-4-2009
Number of Hours:  2.50
Brief Description:  Welded tip holding jigs.
Today I welded together the wing tip jigs that hold the main spars. They go through a lightening hole in the tip rib and the main spar sits in this jig. It's made of 1" square tubing; the base is 5" long, then a 1" spacer and finally a 4 1/4" piece that will act as the spar support.
After welding the pieces to the cross brace, I noticed that there was some flex in the angle iron and that the flat braces were flexing. So I made some support pieces out of 1" angle iron and that shored things up nicely.
Tip post with supports welded on.
Welded tip support.
Welded tip support.
