Pete's Bearhawk Web Site
Date:  8-14-2008
Number of Hours:  1.50
Brief Description:  Finished redrilling the left flap nose skin.
Today I finished drilling the left flap nose skin to the ribs that go against the hinges.
It was quite a process. First, I marked over 1/2" on the spar and redrilled the attach angles to this location. Then I clecoed the nose ribs to the attach angles and installed the nose skin to the spar.
Next, I marked the nose skin out 1/2" from the current holes that border the hinge locations. I first drilled #40 holes to make sure that I was lined up properly. Then I menuvered the ribs to line up with the holes and enlarged the holes to #30. WHEW!!!
Finally I marked the location of the ribs on the skin so I can accurately trim the skin to the proper size.
New hole locations marked
