Pete's Bearhawk Web Site
Date:  3-15-2008
Number of Hours:  2.50
Brief Description:  Worked on the aileron nose skins.
Today I started by marking and drilling the bottom holes in the right aileron nose skin. I then marked the centerline on the nose ribs, aligned the skin to the skeleton and drilled the skin to the nose ribs.
Then, when I flipped it over to start drilling the top, I realized that I needed to bend the nose skin farther so it would sit better against the ribs. So I clamped it down to the bench and hand bent it with some 3/4" MDF. It worked pretty well. Then I decided to put a curve in the skin by hand...also worked pretty well.
Then my 5 year old (Seth) came down to the shop and wanted to help so I put him to work. We flipped the aileron over and marked the hole locations. Then I drilled the holes and he put in the clecos. He was pretty fired up to be helping...good times!
predrilling bottom of aileron nose skin
Mad bending skills!
Mad bending skills!
Cleco man!  Seth's first time helping
