Pete's Bearhawk Web Site
Date:  9-11-2007
Number of Hours:  1.50
Brief Description:  Began drilling the right flap nose skin.
Tonight I began to drill the right flap nose skin. First I marked the center flat part of the nose ribs for center. Then I measured where the ribs are to be and marked them on the nose skin. Next, I clamped the nose skin to the skeleton and aligned the nose ribs and drilled them to the skin.
Once this is done, a marking line is drawn for the bottom flap part of the skin and 4 holes are drilled there. The spar is not drilled into yet because it needs to be clamped to the table to make sure there is no twist in the flap...that is for another day.
First holes in the flap nose skin
Bottom of the flap nose skin drilled
