Pete's Bearhawk Web Site
Date:  8-29-2007
Number of Hours:  4.00
Brief Description:  Began fitting nose ribs to the flap spars.
Today I cut the flap spars to length. Then I marked the hinge and flap nose rib locations. Next I drilled the flap nose rib attach ribs to the spar. Finally, I placed some "skin simulators" on the edges of the spar flange and drilled a nose rib onto an attach angle. This can be seen in the second picture.
I may have just purchased a temporary road block for the Bearhawk...a 1975 Super Beetle. I'm going to have to do quite a bit of work to it which will probably slow construction on the Bearhawk for a little bit but my goal is to still work for at least 30 minutes each day on things. We'll have to see.
Flap spar with nose rib attach angles
Fitting nose rib to flap spar with simulated skin.
