Pete's Bearhawk Web Site
Date:  6-29-2007
Number of Hours:  1.50
Brief Description:  Continued to fit and drill rib attach angles.
Tonight I continued to fit and drill the rib attach angles to the left main spar. I finished by making the special angle that attaches at the splice plate. This involved making 2 more spacer pieces that go under the angle so it is flush with the splice plate. Then cutting the angle to allow the spar attach piece to go under it.
Modified attach angle
Modified attach angle with spacers
fitting the modified attach angle
