The same routine is continuing. When I add more filler I use red glazing putty. The application is very thin each time. I have found that the best results acutually are obtained with the Bondo brand of glazing putty. It sands much easier. If you use glazing putty you must let it comepletly dry as it shrinks. Remember it is really just thick primer.
