I finished the flap system indicator current hook up and the trim indicator hook up. I also add discounnects to the map light and changed the routing on the OAT, map light, altimeter and VSI wiring. I also added the cabin light to the panel between the seats. It still has to be wired to the switch on the instrument panel. The Flap Master switch was also wired into the circuit breaker system. I will explain the flap system and trim system when I finish installing them.
