Brief Description: Priming and Smoothing Main Gear Door
I used Loele black primer for the first coat on this door. It works great and is sandable in 15 to 30 minutes here. I also used glazing putty to fill in minor imperfections. I then applied a coat of Loele white primer and sanded it down. More glazing putty was added over 2 large areas to smoothly transition them better as this door is curved on the outside.
