Davids Web Site
Date:  3-19-2007
Number of Hours:  3.00
Brief Description:  Applying Primer Surfacer
I applied a different primer surfacer, which applies better than any I have used. It is by Advantage and goes on quite smooth. It also does not attack foam rollers. I prefer a 4" roller when applying primer which must be mostly sanded off. Later on in the finishing process I will spray the primer after I have the aircraft quite smooth.
