Davids Web Site
Date:  12-1-2006
Number of Hours:  0.10
Brief Description:  Main Gear Uplock Spring Test
I conducted a simple test of the uplock springs on the aircraft. These were found to far exceed a pull of eight pounds to activate them. I need to get something stronger for this test. Eventually, I will add solinoids to pull these springs normally and have direct mechanical movement only as a backup method.
