Build Log
Date:  8-27-2011
Number of Hours:  1.00
Manual Reference:  DWG4; Manual 6-9
Brief Description:  Cut and bent trim tab hinge pin
Cut and bent the trim tab hinge pin. Drilled small (#40) hole into trim spar to fasten the hinge pin with safety wire (not yet done).
Bent E-919 (bottom trim tab skin fwd of trim tab spar) slightly upwards to clear bottom elevator skin.
Hinge pin bent.
Hinge pin bent.
Bottom part of trim tab skin bent upwards.
