Brief Description: Cut foam ribs, started bending trim tab end ribs
Fabricated brake out of wood boards and piano hinge. Bent the trim tab skin with brake. Cut and sanded the trim tab foam ribs to size. Started bending the trim tab end ribs on the skin. Made a small dent in the bottom side of the skin on the first bent. Ah well, probabely get some bondo in there when its time to paint.
