Brief Description: Started routing fuel line provision for aux-tank
Started routing fuel line provision for a later aux-tank in the baggage compartment. Tried first using a bulkhead fitting in the spar bridge web, but couldn't get the fuel line with the nut into the tight space between the two spar bridge webs. Will just use a line with a free hanging T-fitting. Have to order the appropriate size bushing for the 9/16 hole (where the bulkhead fitting should have been).
