Drilled the fuel pump doubler plate for the Bighead F2/S20-M4x5mm threaded socket to mount the fuel pumpt with shock mounts. The threaded sockets will be rivetted from below with AD4-5 countersink rivets; and then the doubler plate will be mounted on the fuselage floor.
Fuel pump with shock mounts on doubler - provisionally
